OctaneRender™ for Blender 2018.1.2 - 17.7 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Updated to 2018.1.2
  • Reorganize kernel UI layout
  • Have Smoothing on for newly added materials
  • Optimized object upload process(Turn it on at "User Preference-Add ons-Octane-Optimized Object Generation Mode")
  • Now octane will save passes as exr to "Render-Output" folder(to fix the cryptomatte pass export issue)
  • Use blender temp folder("User Preference-File-Temp") to save octane temp files
  • Support "Camera Mapped" in alpha image and float image
  • Add "Toon shadow ambient"("Render-Octane kernel-Toon shadow ambient")
  • Add "Cast shadow" for toon lights
  • Add volume properties in Material panel
FIXES SINCE LAST RELEASE
  • Fix rendering issue when objects are hidden
  • Fix the animation export issue
  • Fix unwanted reflection filter pass in exprted orbx
You can read about new features of OctaneRender™ 2018.1.2 here:
viewtopic.php?f=24&t=71406
1. OctaneRender™ Server
Windows
Blender Octane Edition - 2018.1.2 - 17.7 (2.79)
Octane Server - 2018.1.2 - 17.7
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v2018.1.2 - 17.7 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v2018.1.2 - 17.7 OSX ZIP
