OctaneRender for Maya 4.04-13.38 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 4
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 4.04
Please read the new features implemented from Octane Standalone 4 version our blog post.
Changes since version 13.37:
  • Integrated the 4.04 rendering engine.
  • LocalDB import improved.
Windows DOWNLOAD
OctaneRender for Maya 4.04-13.38 Demo
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 4.04-13.38 [Windows]
OctaneRender for Maya Studio 4.04-13.38 [Linux]
OctaneRender for Maya Studio 4.04-13.38 [MacOS]
Jolbertoquini
Hi Jim,
There is a bug for a while with the plug already 3 version of the plug.
It's when we plug a 2d transform on the spherical projection at the imager on the sunsky node.
If we do a key and try to change while doing ipr doesn't work the rotations anymore.
Before was working well I guess is not forcing loading the changes.
The work around we did was plug the rotation transform at a one locator and key that locator rotations.
But is not really great.
Would be nice if we get a quick fixe on this please.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Please attach some scene where this issue is reproduceable on your side.
viewtopic.php?f=110&t=71302
Jolbertoquini
JimStar wrote:Please attach some scene where this issue is reproduceable on your side.
Okay i will post a video record is pretty straight forward. the scene i will send but is any scene and if you open you want understand. because is while lighting basically for some reason is broked on the presently plug.
Best
JO
Jolbertoquini
Hi Jim,
Please take a look at this video, from the begging you can see the rotation is working while doing the IPR but after key the rotation value is not updated I can see is reloading but is not working as was working before.
Is quite a problem while lighting the shots on the scenes cause we can't preview on the fly the key without stop completely and reload.
after we do the quick fix by adding a locator key to force the plug to load the changes.
Hope this help enough to do, in any scene is like that, is not linked on specific scene problem but plug bug. (cause before was working)
JO
Bug_HDRI_2D_Transform.mp4
Video Preview
(35 MiB) Downloaded 2473 times
nedan
Is the same thing I have mention here:
but it looks like they "can't reproduce this."
Nevermind for me anymore, since I have passed to 2019 and using RS there...
Jolbertoquini
nedan wrote:Is the same thing I have mention here:
Hi Nedan,
I guess with the video Jim can see and understand, Yes is not that simple to spot if we actually doesn't light the scenes with key and etc. Hopefully will be fixed. but check the video the workaround for now.
Best,
JO
Locked
