Posibility of colour temperature slider.
noisyboyuk
Hi!
I'm wondering if it might be possible to have a colour temperature slider or even some colour curves for the HDRi texture object?
It would be invaluable for making adjustments to HDRi's so that the reflections and lighting could match the colour temperature of the backplate I'm compositing for. It would genuinely save so much time if I can take a HDRi I've made and then make it match the colour temperature of the footage or image I'm lighting for.
Thanks!
you can add any kind of Octane mapping node to your ImageTexture in Environment, like Color Correction, Add, Multiply, Subtract, Mix ecc.
ciao Beppe
noisyboyuk
Awesome, thank you!
The only problem is, I can't seem to work out if there are any nodes that allow you to do colour correction. You can change the hue but that's not useful in changing colour temperature or general colour correction (really we need per channel or colour temperature control). Do you know of another way I might achieve this?
