LUA - Track render target changes events
Forum for OctaneRender Lua scripting examples, discussion and support.
enricocerica
I would like to execute some LUA code whenever I start rendering from a render target and when I change for instance the camera position in this render target.
I would like to track those events in my LUA script but cannot find any way to achieve that.
Any suggestion welcome
http://www.myline.be
jobigoud
For the camera changes you'll need to use `_evaluateAllChanges` so the upstream changes on the camera position/target fields trickle down to the script.
Here is a very minimalist snippet showing it. If you expand your RT camera and plug it into the script, every time you change viewpoint the node name will be updated.
local scriptgraph = {}
scriptgraph._evaluateAllChanges = true
function scriptgraph.onInit(self, graph)
    local pinInfoCamera = { label = "Camera", type = octane.pinType.PT_CAMERA }
    graph:setInputLinkers({pinInfoCamera})
end
function scriptgraph.onEvaluate(self, graph)
    graph.name = "time:" .. tostring(octane.util.getCurrentMillis())
end
return scriptgraph
For the "start rendering" I think you'll need to go through a render job.
enricocerica
Thanks Jobigoud,
My script already get the camera info and it works fine but I have to run it each time I select a new render target which is not useful.
To be more clear on my wishes, each time I select a render target I would like an object to be automatically placed at the camera position without any action (I mean not running the script manually).
As I'm using a sphere around the camera in combination with a sphere surrounding the scene to created fog, the sphere around the camera should be placed at it's position when I start render.
Indeed the batch render job may help as the start render could be triggered but I usually render interactively and if I often miss the sphere placement and I should restart everything ...
It's not a big issue but would be cool to enhance my script with this feature ;)
Return to “Lua Scripting”
