Unnecessary temporary files creation
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
This was reported some time ago and is not taken care of. Please remove this caching system or make it optional.
Instead of making editing materials faster it makes it slower and takes disc space.
viewtopic.php?f=32&t=71156
System – Windows 11
linograndiotoy
Hi Bartek,
not sure it's possible to change the fact some files needs to be stored/generated when exporting an ORBX.
For sure it would be great to be able to specify the path where this should happen.
The developer is aware about the issue.
Thanks.
pegot
How about having the final ORBX file automatically deleted after successful export? At the very least there should some kind of documentation or a mention on where these files are located so that users unaware of their creation (as I was) can manually delete them. I only learned about the redundant ORBX after doing a TreeSize scan on my drive to see where in my directories there was a concentration of very large files I could delete from my system.
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
J.C
linograndiotoy wrote:Hi Bartek,
Thanks.
The files are also created when not doing ORBX export. Every time I create material with a texture the copy of this texture lands in the Users "\livedb\client\textures" folder. Can you switch this off?
System – Windows 11
J.C
This option is available in Standalone:
caching option.PNG (6.88 KiB) Viewed 22129 times
System – Windows 11
J.C
The same option to disable texture caching is also in C4D plugin.
Working with this enabled in Blender freezes Blender for few seconds when adding a texture from a disk. Freeze time depends on texture size.
System – Windows 11
DrawFun
Thanks for your report.
An optional cache path will be introduced in 17.7, the coming build.
DrawFun
pegot
That will be very helpful. Thanks guys!
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
J.C
DrawFun wrote:Hi,
DrawFun
What about an option to disable this?
System – Windows 11
linograndiotoy
J.C wrote:
DrawFun wrote:Hi,
DrawFun
I think that's something needed so the whole process can take place.
Return to “Bug Reports”
