OctaneRender™ for Blender 2018.1 - 17.6 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to 2018.1
  • Supported to save material as OctaneDB("Material-Settings-Save As OctaneDB")
  • Supported camera mapped feature in Image Texture Node
  • Supported to customize LocalDB path( "User Preference-Octane Render-Octane LocalDB Path")
  • Supported enterprise package build
  • Compatibility support: auto-link bump/normal to coating bump/normal and sheen bump/normal
You can read about new features of OctaneRender™ 2018.1 here:
viewtopic.php?f=24&t=70809
1. OctaneRender™ Server
Windows
Blender Octane Edition - 2018.1 - 17.6 (2.79)
Octane Server - 2018.1 - 17.6
Linux
OctaneRender Enterprise does not yet support Linux. This is being addressed by our team, and will be amended as soon as possible.
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v2018.1 - 17.6 OSX ZIP
