Ability to export ORBX at runtime from script
Moderator: ChrisHekman
oktomus
Hello !
I would like to export a ORBX file at runtime and from script. I suppose it's not possible right now because there isn't any public API but is it on your roadmap ? Or Octane on Unity is only for artists ?
ChrisHekman
I just checked and this is not currently possible to export to orbx via script.
Ill check if I can enable it.
ChrisHekman
Actually, there is a way to do this atm.
Octane.Scene.Save() will save the scene to Orbx for you.
oktomus
ChrisHekman wrote:Actually, there is a way to do this atm.
Thanks! But i'm not sure it will work in runtime in a build.
ChrisHekman
OctaneUnity in a Standalone Build is not currently supported no.
This would only work in editor, and in editor play mode.
oktomus
ChrisHekman wrote:OctaneUnity in a Standalone Build is not currently supported no.
Ok thanks. ORBX is just a file so it could be technically possible to export it at runtime no ? If so, is it planned or in the back of your roadmap ?
ChrisHekman
The Octane for Unity itself does not work without the editor in standalone for multiple technical reasons. Which means exporting dosnt work without the editor in standalone.
We are looking into a solution, but it is a hard technical problem to solve, so it will take a while.
oktomus
ChrisHekman wrote: The Octane for Unity itself does not work without the editor in standalone for multiple technical reasons. Which means exporting dosnt work without the editor in standalone.
Ok thanks a lot !
Return to “Unity”
