Im about to build a workstation with 2x 2080ti's.
Than the question came up if I should bridge the two GPU's with an NV Link...what is the adventage besides it doubles the VRAM?
Do you have an idea if this could be helpful with other 3d/design related software, such as the C4D, Redshift, Houdini, Adobe Suite, Allegorithmic Software, etc.?
Does it only add together the VRAM or also the cuda cores? This would make a pretty crazy difference for GPU driven simulations for example, right?
Would it speed up something? Doing no harm but also no help? Or would you suggest do even NOT use it
Is this just helpful if you are using your machine as a gaming station, and you need all GPU power bundled to display frames on one monitor?
Also: If I intend to create a two-monitor-setup, would it make sense to hook each monitor to a different GPU? And again, would a NV Link be useful here too...?
Those are a lot of questions....but I hope some of you guys can give me a little bit of better insight here..
Thanks so much in advance,
R.
