Daylight/Spherical Map Ground Permeating into Scene
Vaul85
Hi All,
Probably a 'noob' problem with a simple answer.
I am having an issue with spherical maps and the Octane Daylight system. I have been doing some interior arch vis renders and it seems that the green/ground from the environment and/or spherical map is somehow permeating into the interior of my scene causing a green lighting tint on the inside - living rooms, gym halls etc - even rooms with small windows near the ceiling. I cannot for the life of me understand why this is happening or how fix this. When I worked in Lightwave, I used a dome with a spherical sky texture set to illuminate to light my scenes with OK results. Any ideas?
Cinema 4D 2023
Windows 10 Pro 64-bit
Processor: Intel(r) Core(TM) i7-4930K CPU @ 3.40GHz (12 CPUS), ~3.4
(2) RTX 1038
Hi - try the suggestion in this thread -> viewtopic.php?f=34&t=70690
Vaul85
Hi Paul,
I believe the issue had something to do with the color of my lights.
TY
Cinema 4D 2023
(2) RTX 1038
Return to “Foundry Modo”
