OctaneRender™ for Blender 2018.1 RC6 - 17.5 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to 2018.1 RC6
  • Added normal and bump for coating and sheen in universal material
  • Added simplify settings
FIXES SINCE LAST RELEASE
  • Fixed some disordered issues in LiveDB material
  • Fixed Metal/Toon/Universal material support in LiveDB material
  • Fixed orbx proxy instance issue
  • Optimized material upload - now materials in inactive scenes would not be uploaded
  • Change "Octane LiveDB" in windows menu to "OctaneDB" as it contains both localDB and liveDB
You can read about new features of OctaneRender™ 2018.1 RC6 here:
viewtopic.php?f=33&t=70808
1. OctaneRender™ Server
Windows
Blender Octane Edition - 17.5 (2.79)
Octane Server - 17.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v17.5 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v17.5 OSX ZIP
