unable to render
aw1
hi guys i am having prob rendering with latest plugin i just installed, i am getting this error:
RENDER FAILURE: the render can't be completed. Enable and check the log for more details.
here is the log file:
Started logging on 02.03.19 13:06:49
OctaneRender 4.00 (4000021)
CUDA error 999 on device 0: unknown error
-> failed to link file
device 0: failed to load OSL shader code:
error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
device 0: failed to compile module 0
kindly help.
thanks!
Windows 7 Pro, i7 4770, 16 GB Ram, 1TB SSD, Asus GTX780Ti 3GB
Lewis
That is not latest plugin version and you might also have bad nvidia drivers, have you checked forum STICKy notes about 418.xx Nvidia drivers which brreaks Octane ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
juanjgon
Yes, you should update your NVIDIA drivers to the latest ones, avoiding the 418.x versions, and update also the LightWave plugin to the latest 4.02 build available.
aw1
thanks for your reply,
I am already using nVidia driver version 419.17 (for GTX 1080Ti)
Lightwave 2019.1
Octane plugin version 4.000.0.21 (Nov 16 2018)
Octane API build 4.00
Octane DLL version 4000021
Octane Standalone version 4.02
I just checked everything with Lightwave 2015.3 and having same issues.
Thanks and best regards.
juanjgon
You need to update the LightWave Octane plugin to the latest builds 4.02 or 2018.1. All these new NVIDIA drivers are not compatible with the older Octane versions. If you need to work with them you are going to need to revert back to older NVIDIA drivers, perhaps 417.x or older.
Return to “Lightwave 3D”
