Statusbar saved with final render
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
KeeWe
Hi Ahmet,
Since it happend 2 times on 2 different projects, I thought I would let you now:
When rendering an imagesequence (png, 16 bit), Octane saves the statusbar randomly on one frame.
Unfortunately I could not reproduce it nor see any pattern when it occurs. Additionally it seems kinda rare, I'd guess I rendered about 3000 different frames and got 2 errors like this.
It's not that big of a deal, though it's a little annoying to check every single frame in the final sequence.
Maybe you can use the information though. :)
Version: V4.0.1.1-R2, R19, Win 10, nvidia 417.71
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
Ok! I don't know this issue. Your post needs more information about scene. Are you sure you don't do something wrong on render settings? And open Console window, check render logs for related frames.
KeeWe
aoktar wrote:Ok! I don't know this issue. Your post needs more information about scene. Are you sure you don't do something wrong on render settings? And open Console window, check render logs for related frames.
I know its more or less useless info, but I can't provide more details. It seems its completely random, starting the rendering again does not reproduce the error, rendering the exact frame again works just fine.
I just wanted to let you know, in case you can do something with this info.
Feel free to delete the thread, I just wanted to pass the info to you. :)
can you send me a frame of render with problem and previous frame's render? we can compare and try to make a conclusion
Return to “Bug Reports”
