OctaneRender™ for Blender 2018.1 RC4 - 17.4 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to 2018.1 RC4
  • Supported orbx proxy (now we are able to import external orbx as a proxy)("Properties-Data-Orbx properties-Orbx File Path")
  • Supported to change target node tree when fetching livedb material
  • Supported viewport material color("Properties-Material-Settings")
  • Added "Linear space invert" for texture image nodes
  • Included alembic feature for osx/linux builds
  • Prevented crash when failing to overwrite orbx file
FIXES SINCE LAST RELEASE
  • Fixed motion blur render issue under the preview navigation
  • Fixed material preview render failure
  • Fixed emission issue in mix material
KNOWN ISSUES
  • Due to the current motion blur mechanism, animation for orbx proxy does not work when motion blur enabled
  • Displacement does not work with vertex color/float attributes in the current build(engine team has plans to support it)
You can read about new features of OctaneRender™ 2018.1 RC4 here:
viewtopic.php?f=33&t=70675
1. OctaneRender™ Server
Windows
Blender Octane Edition - 17.4 (2.79)
Octane Server - 17.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v17.4 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v17.4 OSX ZIP
