OctaneRender™ for Blender 4.02.1 - 16.3.3 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Updated SDK to 4.02.1
  • Supported to change target node tree when fetching livedb material
  • Supported viewport material color("Properties-Material-Settings")
FIXES SINCE LAST RELEASE
  • Fixed motion blur render issue under the preview navigation
  • Fixed material preview render failure
  • Fixed default value reset issue when osl texture compiling
You can read about new features of OctaneRender™ 4.02.1 here:
viewtopic.php?f=24&t=70612
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.3.3 (2.79)
Octane Server - 16.3.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.3.3 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v16.3.3 OSX ZIP
