OctaneRender™ 2018.1 RC4
haze
Hi all
We have done several more fixes for bugs reported since 2018.1 RC3. Please be aware that Studio builds of 2018.1 now support only 1 GPU, and no network rendering.
2018.1 and its XB and RC builds will only be available for customers with a version 4 license while 2018.1 is not yet stable. To try 2018.1 you need to upgrade your version 3 license to a version 4 license. This can be done for free via our web shop: https://render.otoy.com/shop/upgrade.php.
Important: Please don't update your NVidia drivers yet, 418.81 and 418.91 both break Octane, please wait for Nvidia to release a fix, which hopefully will be shortly.
Changes since OctaneRender 2018.1 RC3:
  • Fixed crash when trying to save cryptomatte object layer passes.
  • Fixed emission with mix material.
  • Fixed incorrect render when the same VDB is loaded as SDF and as fog volume.
  • Fixed subdivision with vertex attributes (fixes several ABC loading issues).
  • Fixed missing window titles in Lua dialogs if native window titles are disabled in the application preferences.
  • Fixed LiveDB downloads sometimes failing and OctaneLive getting disconnected.
  • Fixed incorrectly exported 16 bit and 32 bit HDR images
  • Fixed network rendering with deep images.
  • Fixed some incorrect behaviour in the universal material when using IOR=1 / transmission=1 and caustic blur.
  • Fixed tonemap failure if over-under stereo is being used on small resolutions and with the eyes swapped.
  • Fixed transform nodes not updating transformations in the scene when there are linkers separating them from nodes.
  • Fixed render failure when rendering a vectron node with an OSL texture input.
  • Fixed render failure when trying to use vertex attributes with displacement. This is not yet supported, but planned.
  • Fixed using greyscale images as opacity maps.
  • Fixed normals for spheres with motion blur.
  • Fixed crash when cancelling a load from Alembic
Downloads for users with a regular license
OctaneRender for Windows (installer)
OctaneRender for Windows (zip)
OctaneRender for Mac OS
OctaneRender for Linux
Downloads for users with a Studio subscription license
OctaneRender Studio for Windows (installer)
OctaneRender Studio for Windows (zip)
OctaneRender Studio for Mac OS
OctaneRender Studio for Linux
Downloads for users with an Enterprise subscription license
OctaneRender Enterprise for Windows (installer)
OctaneRender Enterprise for Windows (zip)
OctaneRender Enterprise for Mac OS
OctaneRender Enterprise for Linux
Happy rendering,
Your OTOY Team
Notiusweb
Hello, some things:
1) Images are exporting 16-Bit correctly, so Very Good!
2) SSS attempts with the Universal Material are still failing to match Diffuse, as Transmission color still becomes a 'reflective shine' (see image below)
3) The outer cone-shell of a Spectron/Volumetric Spotlight, is there some way to blur, fade it, as it looks too harsh when not extended beyond the camera FOV (see image below)
THX!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
PolderAnimation
When using an colour vertex attribute in a specular material in the Transmission octane stops working.
edit: I have send an example file to Marcus.
Last edited by PolderAnimation on Sun Feb 17, 2019 2:00 pm, edited 1 time in total.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
PolderAnimation
I read some time ago that you guys are thinking of making an own caching format. Is that still something you guys are thing about? And in such a system will the compiling of the scene be reduced? Just curious :).
haze
PolderAnimation wrote:I read some time ago that you guys are thinking of making an own caching format. Is that still something you guys are thing about? And in such a system will the compiling of the scene be reduced? Just curious :).
Yes and yes.
bagel
haze wrote:Please be aware that Studio builds of 2018.1 now support only 1 GPU, and no network rendering.
Is this a permanent limitation of the studio subscription version?
Goldorak
Nothing is set in stone, but this limit is in place while we review how we will handle NV Link support for subs (and RTX boost shortly) going forward.
bagel
Thanks for the reply! I was concerned!
I'm just going to leave this here: https://render.otoy.com/requests/?qa=46 ... ense-slave
haze
PolderAnimation wrote:When using an colour vertex attribute in a specular material in the Transmission octane stops working.
Fixed for next release.
coilbook
now these new errors appear without any reasons. these scenes were rendered for months and all the sudden all these scenes do this. Nothing was changed Even isolating one object this scene does this
I was rendering with these drivers for a long time and all the sudden i cannot even open octaneviewport without an error .
denoiserThread0 : Initialization failed. Restart required
CUDA error 702 on device 0: the launch timed out and was terminated
-> kernel synchronization failed
-> failed to load symbol data to the device(const11)
device 0: failed to upload imager params
-> failed to unregister pinned memory
-> could not get memory info
-> failed to destroy CUDA event
-> failed to deallocate device memory
-> failed to deallocate pinned memory
crash octane.MOV
(3.71 MiB) Downloaded 7226 times
