OctaneRender 4.02 for Houdini Production build 4.02.1.1
juanjgon
This is the latest production release of the OctaneRender™ 4.02 for Houdini™ plugin compiled with the Octane 4.02.1 core. This 4.02.1.1 release is available for the Houdini 16.0/16.5/17.0/17.5 latest production builds on Windows x64, Linux gcc6.3.1 and OSX 10.12. This plugin is also compatible with Houdini Indie (While working inside the Indie version, the plugin will have a 4k limited resolution while rendering sequences and the scene export and cloud rendering features disabled)
This build has been updated adding a proper plugin build for the new Houdini 17.5 version!
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
New features
To learn more about the new features and improvements of OctaneRender 4, please check out our blog post, but this a quick list of the main new features that have been added:
  • Overhauled geometry engine that dramatically reduces compilation times.
  • Support for out-of-core geometry.
  • AI Light: Improved sampling of emitters, which is a lot more effective than the old method if you have many small emitters that have only a fairly local effect.
  • AI Denoiser: Cleans up your render, which can dramatically cut render times.
  • Global light inclusion/exclusion.
  • Light linking: Allows the inclusion/exclusion of light IDs in the object layer nodes, which can be used to control the direct influence of emitters on objects.
  • Universal material: Merges the properties of the diffuse, glossy, specular and metal materials into one material.
  • Dirt support in the info channel passes / kernel.
  • Overall performance improvements in the render engine and in loading HDR and OBJ files.
  • Support to capture direct and indirect light separately in the light render passes.
  • Support for emission on sphere primitives.
  • Planetary environment based on the Nishita sky model, simulating the scattering of sun light in the atmosphere to render the sky.
  • UDIM support via the new image tile texture node.
  • Image texture compression.
  • Layer selection in the OpenEXR image export.
Release 4.02.1.1 regular license
https://render.otoy.com/customerdownloa ... _Win64.zip
https://render.otoy.com/customerdownloa ... _Linux.zip
https://render.otoy.com/customerdownloa ... ni_OSX.zip
Release 4.02.1.1 subscription license
https://render.otoy.com/customerdownloa ... n64_vr.zip
https://render.otoy.com/customerdownloa ... nux_vr.zip
https://render.otoy.com/customerdownloa ... OSX_vr.zip
Release 4.02.1.1 demo builds
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... x_demo.zip
https://render.otoy.com/plugindownloads ... X_demo.zip
Standalone 4.02.1 version for the network rendering nodes
https://render.otoy.com/customerdownloa ... _1_win.exe
https://render.otoy.com/customerdownloa ... _linux.zip
https://render.otoy.com/customerdownloa ... _macos.dmg
Release Notes:
RELEASE 4.02.1.1
* PLUGIN FEATURES AND FIXES:
- Added support for Houdini 17.5
- Fixed the Octane light while working in blackbody mode, adding an option to enable the distribution texture.
RELEASE 4.02.1.0
- Fixed a critical issue related to the multiple steps transformations motion blur.
- Raised the allowed transformations motion blur steps in the ROP node.
* OCTANE FEATURES AND BUGS FIXED:
- Fixed emission when used with mix materials.
- Fixed volume step length being incorrect when alpha shadows is disabled.
- Fixed potential issue when rendering more than 256 volume instances.
- Fixed "Automatic" pixel format setting which would still load 32 bit float EXR images and HDR images as 16 bit.
- Fixed network rendering with deep images
Happy rendering,
Your OTOY Team
Jolbertoquini
Hi juanjgon,
Thanks a lot! :)
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
BoriaBorisov
Dont work render volumes then use only octane_light in type BlackBody emission , but texture emission work.
juanjgon
BoriaBorisov wrote:Dont work render volumes then use only octane_light in type BlackBody emission , but texture emission work.
Sorry, there is a problem with the Octane light in this build while working in black body emission mode. The problem is related to a change in the texture node behavior when there isn't a valid texture file.
I'll fix it for the next 4.02 build, but meanwhile, the problem is easy to fix replacing the Octane light HDA in the plugin "otls" folder with the attached one.
Thanks for reporting this issue!
octane_light.zip
(13.8 KiB) Downloaded 304 times
Ferdinand13
Hi Juanjo,
Do you know, when 4.02.1.0 will be available for Houdini 17.5? Thanks for letting me know.
Custom PC, Intel Core i7-6800K, 48GB RAM, 3x MSI GeForce RTX 2080 Super Seahawk EK, Windows 10
Razer Blade Pro 17, Intel Core i7-10875H, 32GB RAM, 1x NVIDIA GeForce RTX 3080, 1x EVGA GeForce GTX 1080 Ti Hybrid (eGPU), Windows 10
juanjgon
Yes, we are going to release first a new Octane 2018.1 plugin build including the plugin for H17.5, but later (probably along next week) we'll release a new 4.02 build (or 4.03, if a new core is available) including also a proper plugin build for H17.5
Ferdinand13
Thanks Juanjo :D
I'm always a bit confused about 2018.1. Is that officially out yet or still in development?
Things are a bit confusion again, because even the 4.02 build that I downloaded from here is not listed on the Otoy/Octane main download page - so I wonder whether that is even an official release? I'm not on the forum as much anymore and it'd be a shame to miss the release of the newest plugin (be it 4.03 or 2018.1).
juanjgon
This is the latest 4.02.1 production build available. About the 2018.1 version, the next one (that will be released in a few days) will also be a production final build.
You should check always this releases forum. The latest builds will be always available here first.
seriawp
Thanks for the information. Very much waiting for the plugin for version 17.5
Ferdinand13
juanjgon wrote:This is the latest 4.02.1 production build available. About the 2018.1 version, the next one (that will be released in a few days) will also be a production final build.
Thanks for the update Juanjo. Will check the release forum.
On a different note, are you also responsible for the Redshift Houdini plugin by any chance? I heard 'Juanjo' mentioned on their forum as well.
