Slow rendering since version 4
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
Hi Paride,
it seems that octane renders slower than it used to. In the video attached is a blank screen and it takes 7 seconds to render it. There are 5 x 2080TIs and 11 x Titans X pascals total 16 cards
I don't understand why it goes to only 240 m samples/s and it takes a while to get to this speed and it took 7 seconds! . I remember octane 3 would do this in a second or less with like 3000 m/s on 780TIs we used to have.
And I think GPUs are also not sued at 100%
slow render.MOV
(1.95 MiB) Downloaded 2175 times
paride4331
Hi coilbook,
I'm not a developer then I cannot respond appropriately, but SA works as 3dsMAx plugin.
Regards
Paride
coilbook
paride4331 wrote:Hi coilbook,
Regards
Paride
Hi Paride,
can you please open octane viewport in a brand new scene and see what is your samples/s then load Octane Profile (attached) into the preset and open octane viewport again. There is a bug. After loading saved preset rendering went from 500 m/s to slowly going to 150 samples/s in the empty scene
I also attached 2 videos. After loading preset profile rendering speed drops a lot
octane profile.zip
(4.57 KiB) Downloaded 269 times
before loading preset.MOV
(2.61 MiB) Downloaded 2175 times
after loading octane profile preset.MOV
(2.77 MiB) Downloaded 2168 times
paride4331
Hi coilbook,
it seems as you report, I will investigate to better undestand.
Regards
Paride
coilbook
Regards
Paride
Also I noticed when denoiser is enabled that's when rendering slows down by half.
paride4331
Hi coilbook,
I made some test, personally I'm not sure there an issue.
Imade a new setting like your and I tested it; then I got your preset and rendered.
To finish I exportated to SA and tested it.
I had 3 same time, so all seems work well.
I will ask to developers what they think.
Regards
Paride
test.mp4
(10.66 MiB) Downloaded 2151 times
Return to “Bug Reports”
