Various issues with V4 plugin
Warp69
Warning - I'm a completely new Octane user :)
When using the OctaneRender for Modo I get various errors and strange behaviours.
I get something like this in the log:
Unable to determine UV index for UV Map [Texture] for mesh [sonsig chassis - left]
Unable to determine UV index for UV Map [Texture] for mesh [chassis holes]
Unable to determine UV index for UV Map [chassis - right] for mesh [chassis holes]
I also have some problems with the resolution - it's so much smaller than the Modo render even though it should use the Modo render resolution.
Any idea to fix the UV index issues?
The Modo render has none of the above issues - I get the correct result.
Thank you
Hi - pls check the manual at https://docs.otoy.com/ModoH/ModoPluginM ... v%20map%22 - and the video on that page.
Not sure exactly what you mean with this. You can scroll the mousewheel to zoom in on the render. You might also have the Preview mode enabled. https://docs.otoy.com/ModoH/ModoPluginM ... ntrols.htm
Return to “Foundry Modo”
