I wonder did anyone noticed that Octane is giving wrong results on ALPHA channel for Glass/specular materials. It's completely white if you use Keep environment option (and it shouldn't be that way) and half broken if is keep environment off.
Please check this and FIX is.
I've included scene for LW, LW+octane and Octane orbx for standalone so anyone can check.
and there is video showing the problem.
Octane WRONG alpha on Glass/specular materials - BUG
- Attachments
- HDRI_Alpha.rar
- (49.82 MiB) Downloaded 319 times
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
More update.
I found when it worked.
It seems that it worked on octane 3.06 <----> 3.08.5 just fine so it got broken sometime in 4.x so it continued to be broken in 4.0x and 2018.x (i tested there also, same issue but i need fix for V4 not just 2018.1)
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
I will check this asap
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
I works for me if I check "Affect Alpha" in the Specular Material Node.
it's on for me and i have thick material of glass (not single poly but proper modeled)pixym wrote:I works for me if I check "Affect Alpha" in the Specular Material Node.
did you check my video , i showed there all the material settings ?
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
Ok I did not see your video.Lewis wrote:it's on for me and i have thick material of glass (not single poly but proper modeled)pixym wrote:I works for me if I check "Affect Alpha" in the Specular Material Node.
Please check my video (it's in first post attached RAR file, video and scene as i explained) and then try with Keep Environment ON.pixym wrote:Ok I did not see your video.Lewis wrote:it's on for me and i have thick material of glass (not single poly but proper modeled)pixym wrote:I works for me if I check "Affect Alpha" in the Specular Material Node.
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
Here is typical Arch-Viz example.
Camera standing inside of a Room, HDRI environment outside.
3.0.8.5 Alpha on windows is good, in v4 is broken (solid white). Attached scene (LW and ORBX) also.
- Attachments
- HDRI_Alpha_ROOM.rar
- (37.31 MiB) Downloaded 345 times
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
Is this problem still present in version 4.02? I can't see any difference in behaviour with 3.07 and 3.08.
What you see in that cube is total internal reflection. Areas where light is reflected are always rendered as opaque even with “affect alpha” switched on.
