CUDA error 719 with Turbulence FD
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
lalalem
Sorry this is my second topic, but this time this isn't because of the NVIDIA driver. I reverted back to v 417.71
A. Windows 10 10.0.17134 Build 17134
B. nVIDIA GTX 1080 Ti Aorus Gigabyte
C. 32Gb RAM 3000Mhz
D. nVIDIA GeForce Game Ready Driver 417.71
E. Standalone not installed
F. OctaneRender plugin version 4.02
G. Cinema 4D R19.053 Student Version
This happens when I work on a Turbulence FD volume. The scene is extremely slow and then "Error Failure" appears.
While trying to render I checked GPU-Z and nothing seemed strange : GPU Load 100%, VRAM usage was 2.8Gb , 54°C, Fan speed 31%, 1500/1900Mhz Core clock speed.
Though I don't know if this is normal, but my GPU rarely (if ever) gets over 60°C when using Octane. I thought it was throttled at first, but GPU-Z gave me the correct CoreClock speeds of 1984 Mhz and GPU load 100% So I guess it's fine ?
Started logging on 06.02.19 10:39:13
OctaneRender Studio 4.02 (4020000)
CUDA error 719 on device 0: unspecified launch failure
  -> failed to wait for event
device 0: direct light kernel failed
  -> failed to unregister pinned memory
  -> could not get memory info
  -> failed to unload module
  -> failed to create link
device 0: failed to create OSL compile context:
device 0: failed to compile module 0
What is the cause of this error ? How can I resolve it ? Thanks a lot !
Lower your gpu frequency and give new try.
lalalem
thanks for your reply aoktar, how can I do that ?
lalalem wrote:thanks for your reply aoktar, how can I do that ?
with some gpu control softwares like msi afterburner
lalalem
ok. how low should I go, do you have any recommendation for this test ?
EDIT : Ok I downloaded MSI Afterburner and changed the clock speed to lower settings. It didn't do anything. Still render failure.
Do you think the problem is that my single GPU is not powerful enough ? I need another one ?
lalalem
Aoktar, I found the problem.... My Volume Step Length was too low (0.001 something like that). I made it higher and all of a sudden Octane got a lot faster and more responsive. :D
lalalem wrote:Aoktar, I found the problem.... My Volume Step Length was too low (0.001 something like that). I made it higher and all of a sudden Octane got a lot faster and more responsive. :D
Ok that's great! having very small values will give much stress to gpus.
Return to “Bug Reports”
