OctaneRender™ for Blender 4.02 - 16.3.2 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Updated sdk to 4.02
  • Supported dragging into image feature for world texture
  • Added post processing in render layer
FIXES SINCE LAST RELEASE
  • Fixed compatibility check_update issue
  • Fixed subscription login failure
  • Fixed memory corruption under some specific resolutions
  • Fixed Transmission input issue in Diffuse Material
  • Fixed the inverted inputs in mix material
  • Fixed render failure when area light size = 0
  • Fixed misspelling errors
  • Modified package naming logic
You can read about new features of OctaneRender™ 4.02 here:
viewtopic.php?f=24&t=70422
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.3.2 (2.79)
Octane Server - 16.3.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.3.2 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v16.3.2 OSX ZIP
