OctaneRender™ for Blender 2018.1 RC3 - 17.3 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Updated to 2018 RC3
FIXES SINCE LAST RELEASE
  • Fixed the type error in transform socket of Checks node
    • This socket accepts Transform nodes only so we removed previous misleading float type socket
  • Fixed motion blur crash
You can read about new features of OctaneRender™ 2018.1 RC3 here:
viewtopic.php?f=33&t=70451
1. OctaneRender™ Server
Windows
Blender Octane Edition - 17.3 (2.79)
Octane Server - 17.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v17.3 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v17.3 OSX ZIP
