error scene
stephen00
Hello,
I have a problem with a scene.
I tested with different versions the 3.8 and the v4.
I have a log memory error gpu unsuccessful with 3.8 but 3ds max does not crash, with the V4. max crash.
The same scene works perfectly with VRAY GPU.
I try to make proxies but that does not change anything.
There is just a basic shader no texture on the whole
PS: Is not the V4 OUT OF CORE?
Thank you in advance, if a person has an idea?
paride4331
Hi stephen00,
this issue should be fixed in OctaneRender for 3ds max v4.02 - 6.13
viewtopic.php?f=80&t=70452
I tested it and it seems to works fine.
Could you test it too?
Regards
Paride
Return to “Autodesk 3Ds Max”
