Hi Juanjo!, i cant figure out how solve this issue. I got some bones with IK, but Octane shows all in the same direction i attach the scene and the screen capture. Hope somebody can help me. thanks!
https://www.dropbox.com/s/0bfmgy72kptry ... R.rar?dl=0
https://www.dropbox.com/s/drwotprl7rcx0 ... 2.png?dl=0
Octane dont show the correct Bones direction (NEW BUG?)
If the objects are LightWave clones, you must disable the "Instance LW clones" option in the render target root node options panel. By default the plugin instance the LW clones, but these instances are going to share the same base mesh, so in this case, you must disable this feature.
Yes...it crash: Log file:
Reading preview image successfully
00:00:14 (0014.01) | [profile] Function "GetPreviewImage" over "" execution time: 0.003 seconds
00:00:14 (0014.12) | IPR: processing image callback
00:00:14 (0014.12) | Reading preview image
00:00:14 (0014.12) | ... Get sampling information
00:00:14 (0014.12) | ... Statistics: 192 of 1000 samples, 0 sec, 62.65 Ms/sec
00:00:14 (0014.12) | ... Get buffers resolution
00:00:14 (0014.12) | ... Resolution: 650 365
00:00:14 (0014.12) | ... Check compositing
00:00:14 (0014.12) | ... Compositing 0
00:00:14 (0014.12) | ... Check sizes for IPR
00:00:14 (0014.12) | ... Reading frame buffer
00:00:14 (0014.12) | Reading preview image successfully
00:00:14 (0014.12) | [profile] Function "GetPreviewImage" over "" execution time: 0.003 seconds
00:00:14 (0014.29) | IPR: processing image callback
00:00:14 (0014.29) | Reading preview image
00:00:14 (0014.29) | ... Get sampling information
00:00:14 (0014.29) | ... Statistics: 256 of 1000 samples, 0 sec, 67.78 Ms/sec
00:00:14 (0014.29) | ... Get buffers resolution
00:00:14 (0014.29) | ... Resolution: 650 365
00:00:14 (0014.29) | ... Check compositing
00:00:14 (0014.29) | ... Compositing 0
00:00:14 (0014.29) | ... Check sizes for IPR
00:00:14 (0014.29) | ... Reading frame buffer
00:00:14 (0014.29) | Reading preview image successfully
00:00:14 (0014.29) | [profile] Function "GetPreviewImage" over "" execution time: 0.003 seconds
00:00:14 (0014.46) | IPR: processing image callback
00:00:14 (0014.46) | Reading preview image
00:00:14 (0014.46) | ... Get sampling information
00:00:14 (0014.46) | ... Statistics: 320 of 1000 samples, 1 sec, 71.13 Ms/sec
00:00:14 (0014.46) | ... Get buffers resolution
00:00:14 (0014.46) | ... Resolution: 650 365
00:00:14 (0014.46) | ... Check compositing
00:00:14 (0014.46) | ... Compositing 0
00:00:14 (0014.46) | ... Check sizes for IPR
00:00:14 (0014.46) | ... Reading frame buffer
00:00:14 (0014.46) | Reading preview image successfully
00:00:14 (0014.46) | [profile] Function "GetPreviewImage" over "" execution time: 0.004 seconds
00:00:14 (0014.62) | IPR: processing image callback
00:00:14 (0014.62) | Reading preview image
00:00:14 (0014.62) | ... Get sampling information
00:00:14 (0014.62) | ... Statistics: 384 of 1000 samples, 1 sec, 73.88 Ms/sec
00:00:14 (0014.62) | ... Get buffers resolution
00:00:14 (0014.62) | ... Resolution: 650 365
00:00:14 (0014.62) | ... Check compositing
00:00:14 (0014.62) | ... Compositing 0
00:00:14 (0014.62) | ... Check sizes for IPR
00:00:14 (0014.62) | ... Reading frame buffer
00:00:14 (0014.62) | Reading preview image successfully
00:00:14 (0014.62) | [profile] Function "GetPreviewImage" over "" execution time: 0.003 seconds
00:00:14 (0014.95) * OCTANE API MSG: CUDA error 700 on device 1: an illegal memory access was encountered
00:00:14 (0014.95) * OCTANE API MSG: -> kernel execution failed(kernel3)
00:00:14 (0014.95) * OCTANE API MSG: device 1: picking failed
00:00:14 (0014.95) * OCTANE API MSG: -> failed to load symbol data to the device(const11)
00:00:14 (0014.95) * OCTANE API MSG: device 1: failed to upload imager params
00:00:14 (0014.95) |
00:00:14 (0014.95) | ++++++++++++++++++++++++++
00:00:14 (0014.95) | +++ IPR RENDER FAILURE +++ processing the failure callback
00:00:14 (0014.95) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:00:14 (0014.95) * OCTANE API MSG: device 0: picking failed
00:00:14 (0014.95) * OCTANE API MSG: device 0: failed to upload imager params
00:00:14 (0014.95) | IPR: reset image callback
00:00:14 (0014.95) | IPR: wait for the getPreviewImage function
00:00:15 (0015.05) | IPR: free the OpenGL buffers
00:00:15 (0015.05) | IPR: rendering done
Yes The plugin i used the last version 2018.1.0.1 then i try with the previous one. Same Crash "Render failure". This is the scene (that version have the Clone option activated.)
Thanks!
Thanks!
- clementvereecke
Hi
I encounter exactly the same problem ! Have you solved this case ?
