Chair rendered with "studio" lighting setup
Daniel
I wanted to try out a studio lighting setup for the first time.
How did I go? What can I improve?
I rendered one more angle and fixed up the model a bit.
Core i7 950 @3.07GHz | GTX 460 2GB | 12GB RAM | Window 7 x64
adiarc
Very realistic. Good job! I like the design too.
stiwi
Hi Daniel,
lighting looks fine to me. But the textures don´t seem right. Maybe a matter of scale, maybe bad textures. Plus the leather doesn´t look smooth enough.
cheers
stiwi
Daniel
Thanks.
stiwi, the actual model itself wasn't the concern, but the presentation of it. I just grabbed some materials off the LiveDB and didn't play with them too much. For the second render I did try to fix things up a bit quickly though.
steveps3
yeah the textures are stretched and the modelling is quite basic. With a bit of work on both you could have a winner on your hands.
(OS) Windows 7(64)
Daniel
steveps3 wrote:yeah the textures are stretched and the modelling is quite basic. With a bit of work on both you could have a winner on your hands.
How do you suggest I improve the modelling without changing the design? Use my creative freedom?
[gk]
chrome parts are low poly
The couplings are non existant making it look cheap ( coupling, welds or clamps ) whatever you decide to do there.
Else rework shaders, add gamma, pump the light.
Worst issue is the wood
Amiga 1000 with 2mb memory card
Daniel
[gk] wrote:chrome parts are low poly
Thanks for the honesty. :)
I fixed the low-poly problem in the second image, since this was primarily a lighting exercise. I might revisit this to add more detail where needed, and spend more than 5 minutes on texturing. :P
steveps3
Also metal chair with wooden base? Looks a bit odd. Maybe it is just because there are no visible fixings connecting the chair to the base. Same applies to the cushion and the chair.
(OS) Windows 7(64)
