Hi all,
Attached is Zap Andersson's halftone shader running in Octane.
This is from here:
https://github.com/ADN-DevTech/3dsMax-OSL-Shaders
Update: I have made some tweaks and added another way to use the shader.
Ideally you would do some post to apply this effect, which you can do currently using render jobs:
Otherwise an alternative is to tweak the imager so that it looks correct from a particular angle:
Halftone shader in Octane
Yes, I was hoping this OSL shader had a good way of driving a parameter based on surface illumination. That's one of the many shader nodes I miss in Octane - just a basic, "get illumination value of the surface and pass it on". I've got a pretty good etching shader I made in Maya that I'd love to port over, but so far I haven't been able to do much with it.Studio21 wrote:Nice...but it acts more of like a dot overlay rather then a halftone. it doesnt react to shadows in regard to the point size etc :/
- Attachments
- etching shader
- singleLeafTest.jpg (17.97 KiB) Viewed 11875 times
