I am having an issue when it comes to Batch Rendering through the Octane 4 plugin.
I have a simple animation scene set up, a ball moving through the scene and a camera move. The render looks good and how I want it but when I got to Batch Render my scene, it does not render out my sequence.
My issue is that of my sequence (1-80 frames) , the batch render will only render one frame. (And it happens to be whichever frame my play-head is on in the timeline.)
I do not get an error when I go to batch render. The command line at the bottom says that it is "Rendering with OctaneRender..." and then a second later, it says that Rendering is Complete. And then when I got into my images file path that I had set up, I see the new folder created, but only the one image of my sequence.
Am I doing something wrong? All my rendering settings seem to be in order, similar to what I would do for generically rendering out of Maya in regards to the Common Settings Tab.
Best,
Batch Rendering Issue MAYA 2018
Hum indeed this is strange, I saw some issues with batch render but not this one.NNelson wrote:I am having an issue when it comes to Batch Rendering through the Octane 4 plugin.
Best,
Nothing more than the usual settings in common tab should be needed,
maybe there is a conflict with another plugin ? hard to guess what's happening here, can you share your sample scene with the bug ?
Pascal ANDRE
