So you have to pay for a Dongle to uses Octane offline?
So I have to basically pay extra for an offline mode?
I'm I corrected?
Dongle info
- spartan00j
- Contact:
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
- spartan00j
- Contact:
Is there a way to use just the standard USB Thumb drive?keviny wrote:You are correct. Once a license is converted to a dongle license, it cannot be reverted to using online authentication.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
Let me clarify. When you purchase a dongle in the shop, you'll be asked to select which Octane standalone license will be paired with this dongle. Next, a dongle is shipped to you. You'll receive the dongle, activate it, and you're good to work offline. What I meant by "cannot be reverted to using online authentication" is that the only way you can use your license is via the dongle. It will no longer ask you to "log in" via online authentication when you launch Octane.spartan00j wrote:Is there a way to use just the standard USB Thumb drive?keviny wrote:You are correct. Once a license is converted to a dongle license, it cannot be reverted to using online authentication.
- spartan00j
- Contact:
okay, Thankskeviny wrote:Let me clarify. When you purchase a dongle in the shop, you'll be asked to select which Octane standalone license will be paired with this dongle. Next, a dongle is shipped to you. You'll receive the dongle, activate it, and you're good to work offline. What I meant by "cannot be reverted to using online authentication" is that the only way you can use your license is via the dongle. It will no longer ask you to "log in" via online authentication when you launch Octane.spartan00j wrote:Is there a way to use just the standard USB Thumb drive?keviny wrote:You are correct. Once a license is converted to a dongle license, it cannot be reverted to using online authentication.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
- spartan00j
- Contact:
How long does delivery usually take?keviny wrote:Let me clarify. When you purchase a dongle in the shop, you'll be asked to select which Octane standalone license will be paired with this dongle. Next, a dongle is shipped to you. You'll receive the dongle, activate it, and you're good to work offline. What I meant by "cannot be reverted to using online authentication" is that the only way you can use your license is via the dongle. It will no longer ask you to "log in" via online authentication when you launch Octane.spartan00j wrote:Is there a way to use just the standard USB Thumb drive?keviny wrote:You are correct. Once a license is converted to a dongle license, it cannot be reverted to using online authentication.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
