OctaneRender for Maya 2018.1rc1-14.9 [OBSOLETE]
Locked
Forum rules:
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSING THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya® Version 2018.1
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 2018.1 are here:
OctaneRender Standalone 2018.1 RC1
Changes since version 14.8:
  • Implemented the workaround for Maya's context-driven API bug triggered by time-warped scenes.
  • Fixed the bug happening for some scenes having references.
  • Implemented the temporary workaround for the Octane SDK bug, causing the render-results to be sometimes incorrect in batch-render if several render-layers are rendered at the same time. Should be fixed in newer SDK versions, but before this happens - this workaround works in my tests... Not sure if it will be reliable for all cases though, the proper fix would be to integrate the fixed SDK version.
Windows DOWNLOAD
OctaneRender for Maya 2018.1rc1-14.9 BETA
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 2018.1rc1-14.9 BETA [Windows]
OctaneRender for Maya Studio 2018.1rc1-14.9 BETA [Linux]
OctaneRender for Maya Studio 2018.1rc1-14.9 BETA [MacOS]
Locked
