OctaneRender™ for Blender 2018.1 - 17.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to 2018-RC1
  • Introduced new refactored mesh structures
    • Introduced "Optimized Mesh Generation Mode". In this mode, animation render is much faster than before.
      • This feature is on by default("User Preference-Add-ons-OctaneRender Engine-Optimized Mesh Generation Mode")
      • Static mesh data(all types except Resharpable) will not be regenerated and reuploaded under this mode
    • The feature is also avaible for preview mode(3D View-Octane Optimization(Preview Mode)-Use Opt. Mesh Generation Mode in Preview)
      • When you tick it on, you are able to change attributes like camera visibility and object id very fast without mesh re-transferring
      • If you want to change mesh point, normal, uv and modifier data, please tick it off and octane will fetch the lastest mesh data
    • Lower memory cost during data transferring between client and server
  • Support vertex color
    • The usage is similar with the SA. Generally, please set the name of the target vertex color in the "Octane Color Vertex Tex" node
    FIXES SINCE LAST RELEASE
    • Changed setup package name format to make it more understandable and easier match with Standalone version
    • Fixed studio license login issue
    You can read about new features of OctaneRender™ 2018.1 RC1 here:
    viewtopic.php?f=33&t=70196
    1. OctaneRender™ Server
    Windows
    Blender Octane Edition - 17.1 (2.79)
    Octane Server - 17.1
    Linux
    Installation:
    $ OctaneServer &
    DOWNLOAD
    Blender Octane Edition - v17.1 Linux
    OSX
    Installation:
    - Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
    DOWNLOAD
    ZIP archive: Blender Octane Edition - v17.1 OSX ZIP
