Universal material - RGB IOR
scratch33
I have a little issue with universal material.
I'm trying to use RGB IOR workflow in it, but something goes wrong.
For exemple, trying to do a brass material. If I enter the IOR values for every colors, in a metallic material, it gives me the correct color ( a very beautiful yellow). If I try with exactly the same values in universal material, it gives me a beautifull but incorrect purple.
Why? What's wrong?
Francesco
juanjgon
Be aware that the GUI order of the six RGB IOR parameters is not the same in both nodes. In the metallic, they are (n,k,ng,kg,nb,kb) while in the universal material they are (n,ng,nb,k,kg,kb) ... probably you need to reorder your parameters values in the universal material.
scratch33
Thanks so much.
How silly I am. I did not notice that the order had changed.
Thanks again
Regards.
Francesco
Lewis
More silly questions, can you (Juan) reorder it to be same order in LW plugin or it's something which is hard-coded by octane core for some reason?
If you can reorder it it would be more consistent.
thanks
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
juanjgon
Reorder these parameters in the GUI should not be a problem. I was already thinking about it for the next build ;)
Return to “Lightwave 3D”
