OctaneRender for Maya 4.01.1-13.25 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya® Version 4
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 4.01.1 are here:
OctaneRender Standalone 4.01.1
Please read the new features implemented from Octane Standalone 4 version our blog post.
Changes since version 13.24:
  • Implemented the "selected GPUs" logging for verbose mode.
  • Implemented the option to skip saving the beauty pass ("additional" section in Octane global settings).
  • Minor auto-conversion improvements.
Windows DOWNLOAD
OctaneRender for Maya 4.01.1-13.25 Demo
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 4.01.1-13.25 [Windows]
OctaneRender for Maya Studio 4.01.1-13.25 [Linux]
OctaneRender for Maya Studio 4.01.1-13.25 [MacOS]
Braca
I noticed a bug. every time I put an IPR and say some time passes and I close the IPR I got a pop up saying "Do you want to save the file..." by clicking YES whole Maya freezes. I am running Maya 2018.5
Braca
I can't reproduce it - works without problems in my tests.
Please PM me the scene having this issue and the exact reproduce sequence description.
Jolbertoquini
Hi Jim,
Here a bug on the export scene with "Time-warp" the power of the lights are not supported we did a export simple animation power animated on frame 120 with untime-warped scene should be power "0" light off, and the time warped scene is from frame 50.
Both export only gives key from the scene with time-warp deactivated. Please do you mind to check other features aswell everything was working fine before refractory plug this now doesn't work properly
I attached the scenes here.
Cheers
JO
Light_Power_TW_ON.rar
Orbx Time warp ON
(4.08 KiB) Downloaded 195 times
Light_Power_TW_OFF.rar
Orbx Time warp OFF
(4.22 KiB) Downloaded 196 times
Light_Power_Test.rar
Maya scene
(9.68 KiB) Downloaded 191 times
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Locked
