OctaneRender for Maya 2018.1rc1-14.5 [OBSOLETE]
Locked
Forum rules:
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSING THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya® Version 2018.1
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 2018.1 are here:
OctaneRender Standalone 2018.1 RC1
Changes since version 14.4:
  • The 2018.1 RC1 rendering engine is integrated.
  • I've got the fixed SDK from Ephere, so: implemented the Ornatrix support for older Maya versions too, including Linux versions. Please report if you got issues with this new feature (with your scene attached).
Windows DOWNLOAD
OctaneRender for Maya 2018.1rc1-14.5 BETA
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 2018.1rc1-14.5 BETA [Windows]
OctaneRender for Maya Studio 2018.1rc1-14.5 BETA [Linux]
OctaneRender for Maya Studio 2018.1rc1-14.5 BETA [MacOS]
calus
JimStar wrote:Note: To make use of Octane vertex color attributes you can create up to two color sets with names starting with "octaneAttr" (e.g. "octaneAttr1", "octaneAttr2") - and use the same names in your OSL scripts.
This worflow for per vertex color is not going to work,
most of the time we can't change easily colorSet name, because it is baked in an alembic or referenced mesh, or procedurally generated .
Why not use instead an Octane attribute at shape level to enable/disable extraction of all colorSets from the mesh ?
Additionnaly in the current workflow the color interpolation between vertex is wrong, but not sure if it's a core or plugin translation issue.
Pascal ANDRE
Locked
