2080 not connected via nvlink
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
umut_sert
Hello ,I have 3 nvidia 2080 founders editon connected to a dual xeon asus motherboard. Although they are not connected via nvlink, octane renderer sees the memory as 24 gb ı guess(available is about 18gb)
And ıt works when ı open a small scene. When ı try to render a loaded scene 3dsmax crashes. My assumption is that it is a nvlink-memory problem. I am using octane 2018 xb2 3dsmax plugin with 3dsmax 2019.
paride4331
Hi umut_sert,
there is a known issue about the VRam that Octane shows. Without Nv-link bridge your available VRam is 8GB.
Without Nv-link bridge, you can only use CPU limit option.
anyway, try taking a look here:
viewtopic.php?f=33&t=69896&p=354045#p352516
Regards
Paride
Return to “Bug Reports”
