OctaneRender™ for Blender 2018.1 - 17.0 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Update to octane 2018 XB2
  • support new 2018 features
  • Vectron
    • Create Vectron Node from "Node Editor-Add-Octane Vectron-Vectron"
    • Select the Vectron OSL file(same as OSL Texture)
    • Assign the vectron for the target mesh(Open "Data-Vectron properties", select node graph then select the vectron node)
    • Please check the attached samples
  • Cryptomatte pass
    • Preview: "Render Layers-Render Passes-Preview pass type"
    • Final render: "Render Layers-Render Passes-Cryptomatte Passes". (The exr files will be put under the folder set in "Render-Output")
  • SDF volume
    • Tick "Data-Volume properties-SDF" on.
    • The usage is same as "Octane VDB" but support surface material rendering
  • New scatter depth limiting
    • "Render-Octane kernel-Max. scatter depth"
You can read about new features of OctaneRender™ 2018.1 XB2 here:
viewtopic.php?f=33&t=70014
1. OctaneRender™ Server
Windows
Blender Octane Edition - 17.0 (2.79)
Octane Server - 17.0
DrawFun
Here are some vectron samples.
vectron_sphere_with_noise.blend
(492.86 KiB) Downloaded 426 times
Vectron_Menger_sponge.blend
(516.66 KiB) Downloaded 400 times
