COMPABILITY 2 DIFFERENT VIDEO CARDS
Area for student license holders to post questions and discuss octane.
User avatar (Default)
merid888
GOOD MORNING I WOULD LIKE TO KNOW IF IS POSSIBLE SHARE 2 VIDEO CARDS INTO A SAME CPU
EXAMPLE: 1 QUADRO FX1700 FOR 2 DISPLAYS AND 1 GTX 1080 TI OC ROG STRIX 11 GB TO USE ONLY INTO OCTANERENDER
MAY USE BOTH CARDS INTO A SAME SYSTEM ? LET ME KNOW PLEASE
THANK YOU FOR REPLY OCTANERENDER TEAM
paride4331
merid888
than you paride, you are so nice, but dosen't say how i can configurate both differents card becouse if you are in the first slot x16 the quadro fx1700 and the four slot x16 gtx1080 oc 11 gb, the motherboard dosen't recognize the fx1700, only the gtx1080 and the s.o. disable the driver quadro and install the driver gtx1080
i can't use both cards for this detail of driver
maybe you know more about this step ?
i use asus p9x79 motherboard
paride4331
merid888 wrote:than you paride, you are so nice, but dosen't say how i can configurate both differents card becouse if you are in the first slot x16 the quadro fx1700 and the four slot x16 gtx1080 oc 11 gb, the motherboard dosen't recognize the fx1700, only the gtx1080 and the s.o. disable the driver quadro and install the driver gtx1080
Hi merid888,
I personally would send your fx1700 retired.
Regards
Paride
mojave
As long as you can find NVidia drivers supporting all cards you intend to use you should be good as long as you don't use that old Quadro FX1700 with Octane as it won't be supported as the latest versions require a card with at least compute capability 3.0 and this card supports CC 1.1.
In general you may combine any number and type of cards in the same system as long as they match the requirements stated here:
https://home.otoy.com/render/octane-render/faqs/
paride4331
Hi merid888,
What Mojave said is correct, but you would like to use that graphics card with 3dsMax and unfortunately it will suck with latest versions 3dsMax viewport, I can assure you.
Regards
Paride
merid888
Actually I just want to use the FX1700 to be able to move objects and textures in 3dsmax, not to render within octanerender, thank you very much for your response, very friendly both
