OctaneRender™ for Blender 4.01.1 - 16.3.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded SDK to 4.01.1
  • Refactored LiveDB and supported LocalDB ("Windows-Octane LiveDB")
  • Added "keep instance power" in BlackBodyEmission and TextureEmission
  • Added "Blend cube transform" and "Coordinate space" in TriplanarTexture
  • Added "Omega" in RidgedFractalTexture
  • Added render priority feature
  • Stored gpu device settings when closing the setting panel
  • Removed old gpu device settings
  • Supported texture for "Ground albedo" and "Ground Emission" in planetary environment
New LiveDB:
The new Octane LiveDB can be found under "Windows-Octane LiveDB". Right click on the target material and then click import to start download. After the download finished, the liveDB material will be put/replace current material. You are able to find it under the material panel(this is same as old LiveDB System).
As this is a totally new system for blender, the old LiveDB is still there "to be on safe side".
FIXES SINCE LAST RELEASE
  • Fixed issue in OSL Projection
  • Fixed issue in deep image
  • Fixed nodegraph issue when " Node Graph Upload Optimization" is on
  • Fixed crash when "Empty GPU After Rendering" feature is on
  • Fixed area light issue
  • Fixed cast shadow issue in emission textures
  • Fixed crash when open livedb without object selected
You can read about new features of OctaneRender™ 4.01.1 here:
viewtopic.php?f=24&t=69925
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.3.1 (2.79)
Octane Server - 16.3.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.3.1 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.3.1 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.3.1 OSX ZIP
