OctaneRender for Maya 2018.1xb2-14.1 [OBSOLETE]
Locked
Forum rules:
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSING THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE - 2018.1 XB1 IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya® Version 2018.1
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 2018.1 are here:
OctaneRender Standalone 2018.1 XB2
Changes since version 14.0:
  • The 2018.1 XB2 engine is integrated.
  • Implemented Linux and MacOS versions.
  • As a workaround for the Autodesk's hair colors bug: Implemented the option to disable the native colors support of Maya hair (new "Disable native colors support" attribute in pfx-object). If disabled, the Maya's native hair colors will be ignored, and the material will be mapped directly using the UVs of the underlying mesh (only one mesh for all follicles of the pfx-object is supported).
  • Implemented the workaround for Maya's numeric UI control bug, popping-up in some special cases for key-animated values.
  • Fixed panoramic camera translation bug.
  • Minor LiveDB fixes...
Note: To make use of Octane vertex color attributes you can create up to two color sets with names starting with "octaneAttr" (e.g. "octaneAttr1", "octaneAttr2") - and use the same names in your OSL scripts.
Windows DOWNLOAD
OctaneRender for Maya 2018.1xb2-14.1 BETA
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 2018.1xb2-14.1 BETA [Windows]
OctaneRender for Maya Studio 2018.1xb2-14.1 BETA [Linux]
OctaneRender for Maya Studio 2018.1xb2-14.1 BETA [MacOS]
calus
JimStar wrote: [*] As a workaround for the Autodesk's hair colors bug: Implemented the option to disable the native colors support of Maya hair (new "Disable native colors support" attribute in pfx-object). If disabled, the Maya's native hair colors will be ignored, and the material will be mapped directly using the UVs of the underlying mesh (only one mesh for all follicles of the pfx-object is supported).
WOW, what a nice surprise, thanks a lot !
Pascal ANDRE
Locked
