OctaneRender for Maya 4.01.1-13.20 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya® Version 4
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 4.01.1 are here:
OctaneRender Standalone 4.01.1
Please read the new features implemented from Octane Standalone 4 version our blog post.
Changes since version 13.19:
  • Engine 4.01.1 is integrated.
  • Fixed global settings UI bug happening for some scenes.
  • Fixed global settings node issue happening with some old scenes.
  • Fixed old scenes' imagers conversion.
  • Improved old scenes compatibility.
  • Fixed minor AE UI bug.
  • Fixed a bug in objects' LOD functionality.
Windows DOWNLOAD
OctaneRender for Maya 4.01.1-13.20 Demo
Linux DOWNLOAD
MacOSx DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 4.01.1-13.20 [Windows]
OctaneRender for Maya Studio 4.01.1-13.20 [MacOS]
OctaneRender for Maya Studio 4.01.1-13.20 [Linux]
sampakinpa
Thank you so much for the update!
2x Xeon E5-2620, 32 GB RAM, 4X GTX1080ti, Windows 10, Octane 3 for Maya 2018, Radeon HD6450 for disply BRIO Animation ltd
calus
This happens when setting camera type to panoramic :
setAttr "perspShape.octCamType" 1;
Tried to access pin via an invalid ID P_STEREO_MODE (227)
Tried to access null node pin
Can't write int to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000007FE90C7E240)
error message continues thousand of lines like this.
Pascal ANDRE
Locked
