normal rendering error
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
when rendering lots of phoenix particles I get this error in RC7. The new build 4.0 crashes even after 1 frame. You cannot even cancel and see the error message. It renders but has an error at the same time.
here is the error. Not sure how it is out of memory when I use CPU ram
CUDA error 2 on device 2: out of memory
-> failed to allocate device memory
device 2: failed to allocate space for geometry (1)
coilbook
also this happens while octane viewport is open due to denoising
CUDA error 700 on device 2: an illegal memory access was encountered
-> failed to download symbol(stats data)
device 2: direct light kernel failed
-> failed to set texture format(__data24__)
-> failed to set texture format(__data26__)
-> failed to set texture format(__data29__)
-> failed to set texture format(__data30__)
-> failed to deallocate device memory
-> could not get memory info
CUDA error 700 on device 1: an illegal memory access was encountered
-> failed to wait for event
device 1: direct light kernel failed
denoiserThread1 : Exited with a error. Restart required
-> failed to unregister pinned memory
-> failed to destroy CUDA event
paride4331
coilbook wrote:also this happens while octane viewport is open due to denoising
Hi coilbook,
what about your TDR delay?
viewtopic.php?f=27&t=69912
Regards
Paride
coilbook
Hi coilbook,
Regards
Paride
Thanks I'll change it. Could you please test the scene I sent to you as PM and add phoenix liquid grid that I attached in the post viewtopic.php?f=80&t=69843&start=20. Thank you
paride4331
Hi coilbook,
yes we'll do it.
Regards
Paride
paride4331
Hi coilbook,
yes we'll do it.
Regards
Paride
coilbook
paride4331 wrote:Hi coilbook,
yes we'll do it.
Regards
Paride
Thank you
Return to “Bug Reports”
