Octane Scatter Question
DJTravisty
I have a plane with an animated displacement falloff in a small section. I am scattering plants throughout the whole plane. However when I animate a displacement falloff on a small section of the plane the seed of the scatter changes on the whole plane. Is there any work around/fix for this besides using two planes?
DJTravisty
This problem only happens when you use a vertex map to distribute in the scatter
Distribution algorithm is not designed for this kind of usage. You can use vertex mode in distribution.
