Write render result to Texture node
Forum for OctaneRender Lua scripting examples, discussion and support.
PolderAnimation
Hi all,
I'm trying to get the "Texture render job" scripted graph to work. I'm not sure if I'm using it correctly, but basically I want to use the render result of the connected renderTarget as a texture for a material nodes diffuse color.
My onEvaluate function looks as follows:
function PTextureRenderJobScript.onEvaluate(self, graph)
    local inputNodes = self:getInputNodes()
    local renderTarget
    for _, inputNode in ipairs( inputNodes ) do
        if( inputNode.nodeType == octane.NT_IN_RENDERTARGET ) then
            renderTarget = self:getInputValue( inputNode )
            break
        end
    end
    PROPS_RENDER_RESULT = octane.render.start( { renderTargetNode = renderTarget } )
    local outputNodes = self:getOutputNodes()
    for _, outputNode in ipairs( outputNodes ) do
        if( outputNode.nodeType == octane.NT_OUT_TEXTURE ) then
            --< CONNECT IMAGE TO OUTPUT NODE >
        end
    end
end
The PROPS_RENDER_RESULT.image returns the image object, but I cannot figure out how to set that to the output pin.
There is no node connected to the output pin, I checked via "outputNode:getConnectedNodeIx(1)", it returns nil.
So I thought of creating a NT_TEX_IMAGE node to connect to it, but then I could not find a way to set the image to it.
The A_BUFFER attribute would seem the most likely candidate, but it only accepts data of type AT_BYTE array.
The octane.image.getRawPixels(image) returns a PROPS_C_ARRAY, but this is not accepted as valid data for the A_BUFFER attribute.
Can this be done, or do I have to save the PROPS_RENDER_RESULT.image to disk and then load it via the A_FILENAME attribute. Seems dirty.
Please help! ;)
Jean-Paul Tossings
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
PolderAnimation
Hi Again,
So apparently I cannot run "octane.render.start" from a scripted graph either, so how do I get this to render?
Sorry for the messy question.
Return to “Lua Scripting”
