I like the way you implemented a SET button on the image resolution tab
Maybe this could be implemented when looking at sample material nodes. Right now if you have make a new material node it automatically gives you a sample window to tweak the material, that's cool... but... If the scene render can be automatically put into pause mode at that time then you can tweak away on your sample and as long as you do not hook any new nodes into the scene you can restart it without losing what you had going. (Even better would be if it could render away in the background, though this may be impossible if the sample sphere is a obj scene in itself.)
Unless I am doing something wrong... whenever I get a new material node window I lose whatever progress I made on the main scene. Sometimes you really only see what needs to be tweaked after 10-15 minutes. Shame to lose that if the node you experiment is not worth plugging in.
Peter
Sample Render Set
- p3taoctane
