Problem rescale object and octane
chechen95
hello im new to octane demo verision and try to learn him as best i can so my problem happen when i resacle an object in my scene that rescale also the texture on it im very lost and need help thank in advance i love octane and no doubt i will buy it soon for my studio.
please, always post some screenshots to better explain your issues.
Please, try to check the Texture Projection node of your Texture, you can change the projection mode and scale whenever you want.
ciao Beppe
chechen95
Thank for your help here is the problem its happen only in projection box mode ( here the gyazo gif) https://gyazo.com/61c462246909a7f6ce5e1248d4c11458
Savvien
That projection mode setting tip was a lifesaver for me. Thanks
This is normal, the Box projection is relative with the dimensions/scale of the projection node.
You can also choose to work in local, or world coordinates.
Please, have a look at the manual:
http://www.aoktar.com/octane/Projection.html
ciao Beppe
chechen95
thank i will keep an eye on it
chechen95
Steiner_91
Okay, I ran into the same issue and now I know why, thanks.
So, if I get things right, you can configurate the tools so that they don't repeat the image over and over again like it's a texture, but so that they will rescale the image as you change the size of its support?
