TITAN Xp score 70 (instead of 238) - help wanted
3dphase
Hello.
Today I built in two GeForce GTX TITAN Xp cards in my system (i7 3930K, Win7-64 Prof SP1).
It seems that all is running fine and properly. But as soon as I ran octanebench I couldn´t believe my eyes.
I get a score of 140 by running both cards simultaneously (instead of 476) - or a score by 70 by running each card separately (instead of 238).
Monitor by nVidiaInspector shows pretty high performance (GPU load between 88 and 98%). Newest drivers are installed. Max. temperatures are below 87ºC.
What could cause the issues? Any help is very appreciated. Thank you in advance.
Andy
87° seems quite high for Pascal GPUs, try to check that there is not dust that is blocking the cooling.
ciao Beppe
artdude12
If you are running these cards on air (not water cooling) then you might want to consider using MSI After Burner or EVGA Precision X 16 to control their temps.
Links:
https://www.msi.com/Landing/afterburner
https://www.evga.com/precisionx/
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
