OSL texture issue / Working with parallax mapping
exeshe4ki
Greetings. My name is Alex, i am concept artist and kinda far away from coding and scripting nature. I would like to ask somebody to help me with this code:
#include <stdosl.h>
shader ParallaxInterior(
	int zUpAxis = 0 [[ string widget = "boolean" ]],
        string filename = "" [[ string widget = "filename" ]],
        int textureFlip = 0 [[ string widget = "boolean" ]],
        int textureFlop = 0 [[ string widget = "boolean" ]],
        float roomDepth = 1 [[ float min = 0.1, float max = 100 ]],
        float widthOverscan = 0 [[ float min = 0.0, float max = 0.9 ]],
        float heightOverscan = 0 [[ float min = 0.0, float max = 0.9 ]],
        int enableMidground = 0 [[ string widget = "boolean" ]],
        float midgroundDepth = 0.5 [[ float min = 0.05, float max = 99 ]],
        float midgroundOffsetX = 0,
        float midgroundOffsetY = 0,
        int enableCurtains = 0 [[ string widget = "boolean" ]],
        output color outRGB = 0.0,
    //user controls remapping
    float roomDepthMult = clamp(roomDepth,0.1,100);
    float heightOverscanMult = 1 - clamp(heightOverscan,0,0.9);
    float widthOverscanMult = 1 - clamp(widthOverscan,0,0.9);
    float midgroundDepthMult = clamp(midgroundDepth,0.05,roomDepthMult-0.01);
    float midgroundOffY = midgroundOffsetY * (textureFlip*2-1) * 0.1;
    float midgroundOffX = midgroundOffsetX * (textureFlop*2-1) * 0.1;
    //global variables & remapping
    vector objI = transform("object", -I);
    if (zUpAxis > 0){
      objI = vector(-objI[0],-objI[1],-objI[2]) * color(widthOverscanMult, heightOverscanMult, 1);		//reorder to match UV for Y up axis
    } else {
      objI = vector(-objI[0],objI[2],-objI[1]) * color(widthOverscanMult, heightOverscanMult, 1);		//reorder to match UV for Z up axis
    color objPOrig = (color(u,v,0.5) * 2 - 1) * 0.5 + 0.5;							//for curtains
    color objP = (color(u,v,0.5) * 2 - 1) * color(widthOverscanMult, heightOverscanMult, 1)  * 0.5 + 0.5; 	//UV seems to be the better approach
    //bases for width/height/depth
    vector sections = step(0, objI);
    color baseDepth = (objP-sections)/(-objI * roomDepthMult);
    color mgDepth = (objP-sections)/(-objI * midgroundDepthMult);
    color baseBack = (objP-sections)/(-objI);
    color baseWidth = baseDepth * roomDepthMult;
    //depth and width ramps
    color baseDepthX = (baseDepth[1]*objI+objP + 1);
    color baseDepthY = (baseDepth[0]*objI+objP + 1);
    color baseWidthX = (baseWidth[1]*objI+objP + 1);
    color baseWidthY = (baseWidth[0]*objI+objP + 1);
    float horizU = baseDepthY[2] - 0.5;
    float vertU = baseWidthX[0] - 1;
    float horizV = baseWidthY[1] - 1;
    float vertV = baseDepthX[2] - 0.5;
    //convert ramps to UV/ST... WIP - not very efficient
    float sideWallsMask = step(0,horizU) * step(0,1-max(horizV, 1-horizV));
    color sideWallsUV = color(horizU, horizV, 0) / 3;
    color rWallUV = (sideWallsUV + color(2.0/3.0, 1.0/3.0, 0)) * sideWallsMask * sections[0];
    color lWallUV = (sideWallsUV + color(0.0, 1.0/3.0, 0)) * sideWallsMask * (1-sections[0]);
    lWallUV[0] = (1.0/3.0 - lWallUV[0]) * sideWallsMask * (1-sections[0]);
    float FloorCeilMask = step(0,vertV) * step(0,1-max(vertU, 1-vertU));
    color FloorCeilUV = color(vertU, vertV, 0) / 3;
    color ceilUV = (FloorCeilUV + color(1.0/3.0, 2.0/3.0, 0)) * FloorCeilMask * sections[1];
    color floorUV = (FloorCeilUV + color(1.0/3.0, 0, 0)) * FloorCeilMask * (1-sections[1]);
    floorUV[1] = (1.0/3.0 - floorUV[1]) * FloorCeilMask * (1-sections[1]);
    color backWallUV = ((baseBack[2]*objI + (objP/2)/(roomDepthMult)) * (roomDepthMult*2) / 3 + color(1.0/3.0, 1.0/3.0, 0) ) * (1 - max(step(0,horizU), step(0,vertV)));
    color midgroundUV = (1.0/3.0 - (baseBack[2]*objI + (objP)/(midgroundDepthMult*2)) * (midgroundDepthMult*2) / 3);
    float midgroundMask = step( 0, midgroundUV[1] * 3 * (1-midgroundUV[1]*3) ) * step( 0, midgroundUV[0] * (1.0/3.0-midgroundUV[0]) );
    midgroundUV = (color(midgroundOffX, midgroundOffY, 0) + midgroundUV) * midgroundMask;
    midgroundUV[1] = 1-midgroundUV[1];
    color curtainsUV = objPOrig * color(1.0/3.0, 1.0/3.0, 1);
    curtainsUV[0] = 1.0/3.0 - curtainsUV[0];
    color finalUV = ceilUV + floorUV + rWallUV + lWallUV + backWallUV;
    //flipping ctrl
    if (textureFlop > 0){
        midgroundUV[0] = 1.0/3.0 - midgroundUV[0];
    }else
        finalUV[0] = 1-finalUV[0];
    if (textureFlip > 0){
        finalUV[1] = 1-finalUV[1];
        midgroundUV[1] = 1 - midgroundUV[1] + 2.0/3.0;
        curtainsUV[1] = 1.0/3.0 - curtainsUV[1];
    color roomRGB = texture(filename, finalUV[0], finalUV[1]);
    color finalRGB;
    //midground switch
    if (enableMidground > 0){
        float midgroundA;
        color midgroundRGB = texture(filename, midgroundUV[0], midgroundUV[1], "alpha", midgroundA);
        finalRGB = mix(roomRGB,midgroundRGB,midgroundA);
    else{
        finalRGB = roomRGB;
    //curtains switch
    if (enableCurtains > 0){
        float curtainsA;
        color curtainsRGB = texture(filename, curtainsUV[0], curtainsUV[1], "alpha", curtainsA);
        finalRGB = mix(finalRGB,curtainsRGB,curtainsA);
    outRGB = finalRGB;
This code from tutorial i've bought and it makes parallax mapping effect for a entire quad polygon or plane mesh while it works in Octane stand-alone version.. And it works fine there.
Once i've trying to jump into Octane plugin for Modo, create material for plane, assign Octane override, connect OSL texture node to diffuse channel in auto-created Glossy Material and then load this code into OSL texture node, there is Error pop-out:
Channel modifier type not found for Octane node type 88
I press ok and it offers to me to create channel modifier. And my problem is that I don't know what exactly i have to create. I did some research, but since i am not a coder or script writer at all, i can't figure out myself how to run this script properly in Octane Plug-in for Modo.
I read through the code as far as i can and can't see where this code takes source Texture/Image to apply parallax mapping effect on it.
Can anyone help me to figure out how to execute this script properly in Octan plugin for Modo?
Here is a short video step-by-step i've done and its self-explained.
https://youtu.be/CPFoRsO-4Vk
Here is a texture, that used by this script: http://exeshe4ki.com/mt-content/uploads ... map_03.png
Thank you.
This error is happening because the Octane File node type is not currently supported by the plugin. I will try to add this in the next release. In the meantime, you will potentially need to render with this OSL code in Octane Standalone (or hardcode the texture filename in the OSL code).
exeshe4ki
face_off wrote:This error is happening because the Octane File node type is not currently supported by the plugin. I will try to add this in the next release. In the meantime, you will potentially need to render with this OSL code in Octane Standalone (or hardcode the texture filename in the OSL code).
Thanks for reply, Paul.
I will try to ask my friends, may be they will do some code work for me.
As far as i understood there is no heavy coding needed.
Return to “Foundry Modo”
