[Bug] Accessing LiveDB causes OctaneServer to crash on macOS
davorin
With the new version 4 OctaneRender for Blender I get assigning a material from the LiveDB to a cube in Blender:
Octane: ERROR starting frame load.
Octane: uploading ERROR.
Octane: ERROR loading camera.
Octane: ERROR setting render region.
Octane: ERROR loading mesh.
Octane: ERROR deleting mesh.
Octane: ERROR loading materials of transform.
Octane: ERROR loading transform.
Octane: ERROR loading render passes.
Octane: ERROR loading kernel.
Octane: ERROR setting GPUs on render server.
Octane: ERROR finishing frame load.
Octane: ERROR starting render.
And OctaneServer crashes immediately with:
Octane Engine v. 16.3
Octane: Starting Octane engine...
Work Scheduler initializing 8 worker threads
Octane: ...started
Octane: Activating license...
Octane: ...activated
Octane: LiveDB cache refresh started...
Octane: LiveDB cache refresh complete
Segmentation fault: 11
This happens with the new yearly subscription license....
Debian 10.2 on AMD 1950X, 64GB RAM, 2 * RTX2080Ti
Octane Blender Studio 2020.1-XB3-21.3
Blender 2.83 E_Cycles
J.C
On my side Blender is crashing, quits itself when trying to assign a material from Live DB.
System – Windows 11
davorin
Opened another ticket with OTOY (o;
Blender just quits with:
Crash log:
# Blender 2.79 (sub 0), Commit date: 1970-01-01 00:00, Hash unknown
bpy.context.area.type = 'MAT_LIVEDB'  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (0.565762, 0.947762, 0.99, 1)  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (0.780449, 0.99, 0.97581, 1)  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (0.828418, 0.99, 0.947323, 1)  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (0.952361, 0.99, 0.9435, 1)  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[2].default_value = 0.2  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value[0] = 1  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value[1] = 1  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value[2] = 1  # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (1, 1, 1, 1)  # Property
# backtrace
0   blender                             0x00000001077651ea BLI_system_backtrace + 58
1   blender                             0x0000000106cabe7a sig_handle_crash + 362
2   libsystem_platform.dylib            0x00007fff598a2f5a _sigtramp + 26
3   ???                                 0x0000000000000001 0x0 + 1
4   blender                             0x00000001072f7a46 mywrite + 422
5   blender                             0x00000001072fff04 write_node_socket + 196
6   blender                             0x00000001072ff3be write_nodetree_nolib + 302
7   blender                             0x00000001072f350d write_file_handle + 18477
8   blender                             0x00000001072f788e BLO_write_file_mem + 30
9   blender                             0x000000010738f728 BKE_undo_write + 424
10  blender                             0x0000000106e3ec2c ED_undo_push + 188
11  blender                             0x0000000106ebe471 ui_apply_but_funcs_after + 609
12  blender                             0x0000000106eb9e07 ui_region_handler + 471
13  blender                             0x0000000106cb862f wm_handlers_do_intern + 1199
14  blender                             0x0000000106cb4afc wm_handlers_do + 28
15  blender                             0x0000000106cb4642 wm_event_do_handlers + 2370
16  blender                             0x0000000106caca10 WM_main + 32
17  blender                             0x0000000106ca8bec main + 1036
18  blender                             0x0000000106ca87d4 start + 52
davorin
Or this one:
blender(59301,0x70000c8fd000) malloc: *** error for object 0x7f911f20bc90: incorrect checksum for freed object - object was probably modified after being freed.
*** set a breakpoint in malloc_error_break to debug
Abort trap: 6
DrawFun
Hi all,
Thanks for your reports.
Currently we are working on a refactored LiveDB system(integrating with both liveDB and localDB) for blender.
Could you please give me a bit more information about the crash?
e.g. did it happen randomly? or just in some specific situations(downloading some specific materials)
DrawFun
davorin
Well it happened most of the time assigning water material from LiveDB....
When I restarted OctaneServer then I could assign it just one time...
Sadly there not much information on the console....just those messages...
Is there a way to dump all LiveDB material for local storage? So OctaneServer only downloads changed or new materials?
Also I don't know what is the best way to move a blender design to another host...as all LiveDB material is lost...you have to re-assign it for every object...
Return to “Blender”
