what I've found out is that lower resolution renders work fine (e.g. 1920x1080 with percentage scale of 100%) but when rendering higher resolution (e.g. 1920x1080 with percentage scale of 200%) server crashes when Octane trys to denoise, RAM and vram usage is similar when using denoiser or not.
attaching simple scene
regards
Server crashes when denoising
C. RAM Capacity (i.e. 6 GB)
- Attachments
- server crash.blend
- (858.93 KiB) Downloaded 192 times
I'm getting the same crash while rendering animation at only 1920 x 1080, I've also gotten it while moving around in the real time viewport. I Was rendering volumetrics with no geometry outside of a single geometric plane in the scene.dktw wrote:what I've found out is that lower resolution renders work fine (e.g. 1920x1080 with percentage scale of 100%) but when rendering higher resolution (e.g. 1920x1080 with percentage scale of 200%) server crashes when Octane trys to denoise, RAM and vram usage is similar when using denoiser or not.
regards
Specs:
Os Win 10
3x GTX 980 onboard, 3x GTX networked
Nvidia Driver 417.01
Octane v4/Blender 16.3
