c4d Octane-R18.cdl64) crash after update
visuall
Hello, Since updating the plug-in (c4d Octane-R18.cdl64) crash when closing C4D, someone knows where the problem comes from?
Thank's in Advance
_BugReport.zip
(126.2 KiB) Downloaded 184 times
OCTANE STANDALONE 4 | Octane For C4D | Win7/64 | 2XGEFORCE GTX1060| I7 3770 | 32GB
Could you please try without other plugins?
visuall
To answer your previous question, it's when I close c4D that the problem occurs.
Now C4D does not close properly, I have to kill the task to close it.
I reinstall octane 3.08 and plugin 3.08 but the problem is still present.
It sounds like a blockage on quit! Did you try without another plugins installed?
visuall
I just tried. I no longer have the lock when closing c4d, I'll have to look for what plug in is problematic ...
For info, R19 no problème with all plugin, To say nothing ;)
Well! Let me know which plugin caused the lock!
visuall
Well, after several tests again, it does not come plugin, but some heavy scenes, impossible to close c4d.
I did not yet touch the settings of my system. I do not understand anything anymore.
visuall
Hi Oktar,
Now with R19 the same error at closing.
My system would it be at the end of its life?
_BugReport.zip
(21.17 KiB) Downloaded 176 times
visuall wrote:Hi Oktar,
_BugReport.zip
I don't think so! Is it happening when you have a heavy render in Live Viewer? First close LV and try quit!
visuall
YES when I have a heavy rendering, I close LV always first. and when i get c4d it's always at that moment.
