16.3 Bugs
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
Thanks for the new release. Feels smoother and the black bug seems to be a history. Nevertheless there some old and new bugs:
1. Material node groups are not working anymore.
2. No Deep image support.
3. Planetary environment has missing texture inputs - only colour available for Albedo and Ground emission.
4. Octane properties UI is not optimized as proposed.
5. There are some errors in log:
Tried to access pin via an invalid ID P_SUN_DIR (231)
Tried to access null node pin
Node type 6 is either unknown, a linker or incompatible to static pin 'rotation' (P_ROTATION, type PT_TEXTURE) of node 'mat octane' (NT_MAT_GLOSSY, 0x7f85769468c0)
Tried to access pin via an invalid ID P_POST_PROCESSING (136)
We can't evaluate items of a different version (version 0)!
Tried to access pin via an invalid ID P_POST_PROC_ENVIRONMENT (137)
Tried to access pin via an invalid ID P_PREMULTIPLIED_ALPHA (139)
Tried to access pin via an invalid ID P_RENDER_PASS_LIGHT_6 (172)
Tried to access pin via an invalid ID P_UNKNOWN (0)
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x11b4a0f78)
Tried to access pin via an invalid ID P_AI_LIGHT_STRENGTH (385)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x11b4a0f78)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x11b4a0f78)
Node type 6 is either unknown, a linker or incompatible to static pin 'rotation' (P_ROTATION, type PT_TEXTURE) of node 'mat octane' (NT_MAT_GLOSSY, 0x7f857458b5b0)
System – Windows 11
J.C
Another log errors:
System – Windows 11
Return to “Bug Reports”
